Mikm
I don't understand this one. Can you video what is happening?
Sure, see the video, I just went from recording mode to Frame adjustment mode and when pushing the < > button(s) the frame on screen jump to totally zoom out.
314
477
This might be a new limitation. It seems it was broken in V7.4 (v7.3 is okay). So two steps forward, one step back. In three weeks no one else has reported it, as we general frame, then capture, not capture then frame. It is a bug, and worth looking into.
sheider
22
I've seen this bug, but I didn't bother reporting it because it only happened once and I couldn't repeat it. Anyway, the workaround is simple enough: restart the unit. That said, if you are able to find and fix the bug, then you rock, as always!
JKCalhoun
Hi, all—
Just picked up the Kodak REELS. I was able to digitize an old 8mm reel my daughter found at an estate sale—with the shipping firmware.
Trying to install various firmware versions I have found in this thread have failed to work on my device. I also am unable to find a default firmware that will restore the device. Any ideas?
FWIW, S/N: H2825148BK00161
It was not recognized by the lookup tool so suggested version B.
A and C give me a messed up display when the machine powers up to the Home Screen.
B looks good (the Home Screen), but the buttons do not function.
Thanks!
314
477
Hi, all—
Thanks!
Do the buttons work with type A or C? If this is a new configuration, it would nice to see what it shares with other configurations.
MHreels
Hi, all—
Thanks!
Hi JKCalhoun , I have a European version bought in Nov 2025 which works with the attached original Kodak FW for H2324148BK Series. Might work for you too. Good luck.
  • Kodak FW for H2324148BK Series.zip
Reactions: Mac84
Mikm
Thanks Odano,
I always start to adjust the frame first however from time to time I need to re-adjust the frame while I'm recording.
(it happens when it moves to another part/scenario of the film (reel consists of several small films, all super-8), do not know why or how this can occur with the same reel, not all my reels have this behavior).
The re-adjustment issue as described is always: Buttons to adjust the frame freeze and 3times out of 5 re-tries it even jump to total zoom-out and freeze.
Mac84
301
425
New Jersey, USA
www.mac84.net
Oh interesting! Let us know @JKCalhoun if this works for you, if so, this may be a new model "D" variant.
Also, I finally opened the replacement unit I got in January, the serial number is:
K3124148bk00221
I can dump this to see if it's a "newer" version too.
JKCalhoun
Thanks for uploading the European firmware, but it did not work. The screen was rotated 180 degrees and the colors clearly wrong (as though inverted or just the RGB values shifted or such). The buttons did not work either.
From my experiments with the various A, B, and C versions yesterday, the buttons did not work for any of them. I tried the arrow buttons to see if I could navigate off of the "Capture" button (nope)— I tried the "OK" button to see if it would take me to the next screen (nope).
Maybe Steve has a newer version like mine.
(My S/N: H2825148BK00161)
